Transmission voltage in dB microvolts
Discussion in 'Wireless & RF Design' started by krogerson2, Jan 8, 2009.
  1. krogerson2
    Jan 8, 2009
    24
    if i have a signal that is .4 μV and it is on a 50Ω system how do i express this in dBμV i tried the .4μ/.2236 and then took 20 log of that and it didn't work
  2. KL7AJ
    Nov 4, 2008
    2,043
    292
    I don't know where you got the .2236 from.
    Db(uv) = 20 log (v1/v2)=20 log(.4/1)=20 log (.25)=-7.95 db(uv)
  3. krogerson2
    Jan 8, 2009
    24
    thank you i was getting the .2236 from the square root of .001*50 formula
  4. krogerson2
    Jan 8, 2009
    24
    if a microwave transmitter normally requires a +8dBm audio level to driave the input fully. if +10dBm is measured what is the actual voltage level measured assuming a 600ohm system
  5. KL7AJ
    Nov 4, 2008
    2,043
    292
    As long as you're keeping all your calculations in voltage, you don't have to convert to power...the impedance cancels out. (This assumes the same impedance for input and output signals). If you're calculatiing db for POWER, you'd use 10 log (p1/p2).
    Eric
