1. The characteristic impedance of a transmission line is given by the equation:
A transmission line-under-test has the following primary constants:
L = 100 x 10-9 Henries per metre
R = 4 x 10-3 Ohms per metre
G = 1 x 10-7 Siemens per metre
C = 20 x 10^-2 Farads per metre
Calculate the magnitude of the characteristic impedance with an 8 kHz line
signal frequency. Comment on the result and mention any reasonable
assumptions made in your solution.
1. Am I correct to square root this equation?
2. Now I have completed the equation, should I have broken it down into stages to reach a resolution?
