Transmission Lines calculations
Discussion in 'Homework Help' started by Kayne, May 7, 2010.
  1. Kayne
    Thread Starter Active Member
    Mar 19, 2009
    105
    Have worked though another transmission line question is someone able to tell me where I have made the mistakes.
    A section of air spaced-two wire transmission line is to be made form a roll of 3mm diameter copper wise. The velocity factor is unity. The line is to be 1.5 wavelengths and operates at 15MHz.
    1.What length of wire is required to make the line.
    λ = 3x10^8/15x10^6 = 20metres
    2.What is the centre to centre distance must the wires be placed to make a line with a characteristic impedance of 400Ω
    Zo=276Log2D/d
    400/276 =Log 2D/3
    10^1.449=2D/3
    28.119/3=2D
    9.373 *2= D
    D= 18.746mm
    When the transmission line is used to feed a load at 7.5MHz it is found that a standing wave exists. The load impedance is found to be 100 Ω
    3.Calculate the Reflection Coefficient and then VSWR
    Г =(Zl-Zo)/(Zl+Zo)
    =400-100/400+100
    =3/5
    VSWR = 1+ Г/1- Г
    ={1+(3/5)}/ {1- (3/5)}
    =4
    4.Distance between adjacent voltage minima in the standing wave pattern
    λ = 3x108/7.5x106 = 40metres
    I dont think that this is correct??
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Haven't checked all answers but part 2 is incorrect. Just a math error.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    VSWR=4 is correct
    The SWR minima / maxima are spaced at 180 electrical degrees or at half line wavelength intervals.
  4. Kayne
    Mar 19, 2009
    105
    TNK I can see the error that I made, wrote it down wrote in my note book.
    Zo=276Log2D/d
    400/276 =Log 2D/3
    10^1.449=2D/3
    28.119*3=2D
    84.410 /2= D
    D= 42.20mm
    Is there a formula to work Number 4 or am I on the right track...
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    You are on the right track - the maxima & minima are separated by λ/2 not λ.
