Transmission Line
sam123456
Joined May 1, 2013
Coaxial cable often has a characteristic impedance of 50  and is connected to 50  loads. Assume we have a 50  load but only have ribbon cable transmission line which has a characteristic impedance of300 .
(a) What length of ribbon cable will give maximum power transfer into the 50  load.
(b) What is the SWR for this case?
WBahn
Joined Mar 31, 2012
30,062
You need to show your work and an honest attempt to solve YOUR homework problem. We can then use that as a springboard to help guide you along a path the rest of the way.
