Transmission line
Discussion in 'Homework Help' started by bob smith112, Feb 7, 2011.
  1. bob smith112
    Nov 14, 2010
    8
    hi can i get my home work checked please
    thank you
    bob
  2. mik3
    Feb 4, 2008
    4,846
    63
    I haven't checked your calculations but the method is correct. One thing that supports your answer is the fact that the sending end voltage is greater and leads the receiving end voltage which is the case for real power flow. Real power flows from the end with the leading voltage to the end with the lagging voltage.
  3. bob smith112
    Nov 14, 2010
    8
    hi thank you ithink i made an error in my current at recieving end i should have a angle of -36.87 degrees
  4. mik3
    Feb 4, 2008
    4,846
    63
    But the angle in your calculations is -36.87.
  5. bob smith112
    Nov 14, 2010
    8
    yea i made changes to the second attachment for the -36.2 angle
    is all the other calculation sound?
  6. mik3
    Feb 4, 2008
    4,846
    63
    I haven't checked the calculations one by one but the final answer looks correct for the reason I mentioned before.
  7. bob smith112
    Nov 14, 2010
    8
    thank you
    you have been a great help
    i have just started working on the whole complex numbers
    thanks again bob
