Transmission line phase
Discussion in 'Homework Help' started by jamus, Sep 13, 2013.
  1. jamus
    Feb 11, 2013
    54
    Simple question. In my electronics course, impedance was modeled as causing the current to lead or lag the voltage. Was this more of a "tool" or does it basically apply everywhere?
  2. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,516
    Not sure what you mean by 'everywhere' but normally the current lags voltage in a purely inductive circuit.
    Max.
  3. JoeJester
    Apr 26, 2005
    3,401
    1,218
    I would say "everywhere" you have an impedance, you will have conditions a lead or lad condition.
    Your lab associated with this should illustrate and reinforce the "ELI" and "ICE" conditions.
  4. jamus
    Feb 11, 2013
    54
    What about in the case of a transmission line with a distributed inductance and shunt capacitance? The Vout would have the same characteristics as equivalent circuit elements?
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Since a transmission line looks like a low pass filter I would expect the phase to be a function of frequency.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    For the question to make any sense, you need to be clear on the conditions you are talking about. In general, for the course you are almost certainly in, this means:
    1) Sinusoidal steady state operation.
    2) Linear systems.
    In general the voltage across a device will lead the current through that device by an angle that equals the impedance angle of the device.
    Of course, keep in mind that the impedance angle could be zero, making the voltage and current in phase.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    If you are talking about transmission line theory in which you have distributed inductance and shunt capacitance (and possibly resistance and shunt conductance), then you need to take a step back and walk through the notion of "characteristic impedance" and what that means and how it is derived.
  8. vk6zgo
    Jul 21, 2012
    677
    85
    Reactance is that property which causes the current to lead or lag the voltage by 90°
    Impedance is normally used for circuits which possess both Inductive & Capacitive Reactance (& in the real world,resistance).
    Depending on the relative values of the two types of Reactance,current may lead voltage or vice versa,but,except where one Reactance =0Ω,it will not be by 90°.
    Resonance
    For every LC network,there is a frequency where Inductive & Capacitive Reactance are the same value.
    At those frequencies,the voltage & current as applied to the input terminals of the network are in phase.
    Hence the impedance at Resonance appears resistive.
  9. jamus
    Feb 11, 2013
    54
    Alright, thanks for the help. I get it now.
