Transmission line parallel fault
Discussion in 'Homework Help' started by qwerty11, May 11, 2013.
  1. qwerty11
    Apr 9, 2013
    9
    I am trying to draw the bounce diagram for the trans line in the picture attached to my thread.
    Sorry wont let me upload.....
    https://www.dropbox.com/home#!/light...r%202/mbgm9mw6
    I am not sure what to do here because I have never seen anything like it before. It loos like there is no Zo for the branch involving the load resistance of the fault.
    I need to find the times taken for the wave to arrive at the load resistor and for the primary reflection to arrive at the source.
    Then the magnitude of the primary reflected wave, then the voltage V1.
    Any ideas welcome! If you know anything I could read up on, then that would be helful too. Thanks :).
  2. JoeJester
    Apr 26, 2005
    3,394
    1,213
    Click the Go Advanced button and then scroll down to manage attachments. The new window will have you browse to select your diagram and then click upload. Then close that popup and submit.
