Hi guys how are you? Im currently taking this manufacturing course where we have to build a powersupply, and currently I am in the stage of constructing a PCB using trax maker. Im having trouble translating the PCB from the Schematic I find myself questioning certain connections and being unable to make a connection due to certain restraints. If you could, I have attached a small image of the connection im referring to...
Currently Capacitor 1 (C1) is attached to R1 with a track. and then R1 to C3 throught a track connected to U1 (which is a regulator in this case).
My question is...there has to be a track going to U2 (also a regulator). If at N (Node1) I connect to U2 before R1...is that the same as moving N1 between R1 and C3 and then connecting it to U2?
Srry if thats not so clear I've been working on this damn thing for so long I've had to erase and start over so many times at this point im just so frustrated.
What makes this so difficult to is that there are constraints regarding board size, fixed regulators etc etc.
