Transistors
Discussion in 'General Electronics Chat' started by Sidd, Apr 20, 2014.
  1. Sidd
    Apr 20, 2014
    Hi there everybody. I was wondering if I could get some help. I'm looking to add a transistor to my project to switch a 12 volt circumstances on and off using a low voltage trigger. Could somebody help me pick the right size transistor or direct where to find out more about wiring the circuit correctly.
    Hobbyist
    Sidd
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Hi Sidd. What's all this "circumstances" you are switching on and off?
    About how many volts is the low voltage trigger?
    And welcome to the forums!
  3. Sidd
    Apr 20, 2014
    Thanks for the reply, ErnieM
    I'm looking to switch a pneumatic selonoid (12v), using an arduino(5v). I've tried some transistors (2n 4401). But I've fried a couple of them. I've seen a few videos on YouTube,but after following them step by step still no dice. I'm looking to learn a bit more about them to get the proper size, to build a circuit correctly.
    Sidd
  4. crutschow
    Mar 14, 2008
    13,469
    3,356
    What current does the solenoid require to operate?
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    And, do you have a suppression diode across the relay coil?
    ak
  6. Sidd
    Apr 20, 2014
    Hi there, the power source I've been using to power the selonoid manually has an output of 24v dc .5a
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    But that doesn't tell me what the solenoid requires. What's the solenoid coil resistance?
