Transistors
Discussion in 'General Electronics Chat' started by skiddman, Jan 27, 2013.
  1. skiddman
    Nov 7, 2012
    26
    what happens when you heat a transistor what normally would happen to the currents
  2. WBahn
    Mar 31, 2012
    18,092
    4,918
    It gets warmer.
    Without more information, that's about all that can be said since it depends on the circuit it is in.
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    Is this a bipolar transistor or a field-effect transistor?
  4. MKCheruvu
    Member
    Nov 20, 2012
    30
    6
    In a transistor (in any material) electrons are attached to their parent atoms and are to be dislodged by applying Energy(Voltage) to make them flow - which is called current fllow.
    The amount of energy required, to dislodge depending upon how strongly they are attached/bonded to their parent. Heat ,light are also different forms of energies which when applied will dislodge electrons and there by increase the current flow.
  5. WBahn
    Mar 31, 2012
    18,092
    4,918
    But just heating a transistor does not mean that more current will flow. If the transistor is in a circuit driven by a current source, then the current won't change but the voltage across it will. Also, there are other factors at play in different types of transistors. CMOS circuits, for instance, because faster at very low temperatures and at very high temperatures due to different phenomena.
