Transistors
Discussion in 'Homework Help' started by sinewave, Apr 13, 2004.
  1. sinewave
    Apr 13, 2004
    Please help me, I have some homework to do. I need to know everything possible about bootstrap biasing, and emitter feedback biasing of an NPN transistor. Please help. Thank you
    Derek Belore
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    i will try to be as simple as i can get, Bootstrapping is used to increase the input impedance of a given circuit stage. however it is effectively only if the emitter resistor #1 is >> than the transistor junction resistance dictating not less than the maximum voltage gain.
    it must also be beared in mind that bias stability is also degraded since β (Re1 + Re2) must now be much greater than Rb1 // Rb2 + Rb3 and Rb3 is usually large.
    check this formula Zin = Rb3 + (rj + Re1/ rj) // β (rj + Re1)
    provided that Rb3 >> Rb1 // Rb2
    and Rb1 // Rb2 >> Re1
    in the emitter follower it also gives a high input impedance to the source and a low output impedance to the load. bootsrapping parts like a resistor and capacitor connected in series between the transistor emitter and base are used to eliminate Rb1 & Rb2 from the input impedance equation. the voltage gain is non-inverting and slighly less than 1.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
  4. sinewave
    Apr 13, 2004
    Thank you very much guys, I am finishing my project now as we speak.
