Transistors
Discussion in 'General Electronics Chat' started by rider, Aug 11, 2008.
  1. rider
    Aug 11, 2008
    I am new to electronics - on a transistor, is it required that the voltage feed to the Base is from the same power source (but reduced by a resistor) as the same power source that feeds the Collector (+) and the Emitter (-).
    I wanted to have a 12 volt circuit feeding the C/E with a separate circuit (5 volt) feeding the base?
    Dick
  2. silvrstring
    Mar 27, 2008
    159
    comment removed by moderator
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As long as the 5 volt supply shares the common with the 12 volts, there will be no problem. Just select the correct resistor to limit base current.
