Transistors for IR Repeater
Discussion in 'The Projects Forum' started by SpiderSpartanju, Jul 28, 2010.
  1. SpiderSpartanju
    Thread Starter Active Member
    Apr 10, 2009
    49
    I'm preparing to make a IR repeater much like the one at Radiolocman.com. I plan on using 2n2222 or 2n3904 transistors in place of the BC549 and BC337. Is there any problem with me doing that? I'm also using a 4.8V power supply instead of 9V. Thanks for any help.
  2. windoze killa
    Feb 23, 2006
    605
    24
    I would check the data sheets for each and see if the Hfe figures are similar. I wouldn't expect too much of a problem. They are all general purpose transistors.
    SpiderSpartanju likes this.
  3. SpiderSpartanju
    Apr 10, 2009
    49
    Thank you very much for the help. After looking at the data sheets I think I'm going to use a 2N3904 in place of the BC337 and a 2N4401 in place of the BC549.
