transistor
Discussion in 'General Electronics Chat' started by bhuvanesh, Sep 15, 2013.
  1. bhuvanesh
    Aug 10, 2013
    268
    see the above image .in first circuit i added 0.1 ohm resistance i got around 6 v in emmiter side.and then i replaced it with 2.1k then i got 11v as out put .this is why and my supply is 12 v
    plzz help me
  2. #12
    Nov 30, 2010
    16,704
    7,342
    plzz help you what?
    Help you connect a transistor to the correct end of a battery?
  3. ScottWang
    Aug 23, 2012
    4,932
    777
    You have to exchange the C and E of 2N1132A.
    And you can't only in series with a 0.1Ω to the B of bjt, it will burn out the bjt, you only can be in series with 0.1Ω to E or C of bjt.
    #12 likes this.
  4. bhuvanesh
    Aug 10, 2013
    268
    exchange of c and e meant
  5. ScottWang
    Aug 23, 2012
    4,932
    777
    Moving C to E and Moving E to C.
    You better using Rb(R1) at least from 1K, you can reach to 47K or 100K, it depends on how much C current you want.
