Assuming a JBT transitor is connected in such a way that 1k resistor is connected to the source of 12 volt and connected to the collector, and the emiter is ground, with that set up, the voltage across the 1k resistor should be zero since the base of the transistor is open so the transistor should be off. But i found that isn't the case when i use BC549 transistor. from 1-7v, that is correct, but after that, i start reading voltage across the resistor.
