marshallf3
- Joined Jul 26, 2010
- 2,358
We know they've apparently cut your country off from Google but can you get to Wikipedia?
http://en.wikipedia.org/wiki/Oscillate
Not that I can tell. Why would Google be blocked in India?We know they've apparently cut your country off from Google ...
now, i am understanding how to select voltage but have doubt in turning on transistor for some portion, pls sir, give some example of it for better understanding..!If you are inputing a sine wave to the base then the bias voltage you select should reflect whether you want the transistor 'on' for the entire 360 degree sine wave, or just a portion of it.
the link is showing this images!!Since you do not know how to properly bias a simple transistor circuit then look in Google for a phase-shift oscillator circuit. I looked and found a site with a schematic, a parts list and an oscilloscope photo of its waveform. Here is the site:
http://www.visionics.ee/curriculum/Experiments/RC%20Phase%20Shift%20Oscillator/RC%20Phase%20Shift%20Oscillator1.html
I don't know what the squares are for but did you scroll and see the parts list, schematic and 'scope waveforms?the link is showing this images!!
what does it mean??
If you go to school and learn about transistors or read about them on the internet then you will see that the potential divider that makes the base bias should have a current that is 10 times to 20 times the base current. This circuit has the current in the potential divider about 14.5 times the base current.still having some question about, calculating the value of resistance in potential divider bias.
as how to find value of resistance pls give some more example of it.
I once used 4.7K resistors because that was all I had. I would have prefered to use 10K resistors so the overall current use would be lower, but, guess what?, BOTH of them worked just fine.still having some question about, calculating the value of resistance in potential divider bias.
You forgot to post the schematic that shows R2.I seen in Robert L. Boylestad (elect. book), it give a relation (beta)*Re>= 10*R2 (Testing Condition) what does it mean??
What does this mean??Similar to saying that the current in the potential divider should be 10 times to 20 times the base current.
You need a better translation program. "The current in the potential divider should be 10 times to 20 times (more than) the base current (of the transistor)".What does this mean??
pls give example.
by Don Wilcher
by Duane Benson
by Duane Benson
by Jake Hertz
