transistor
It is a relay with a driver transistor.What it this circuit ?
It could be a wide variety of transistors. Generally, you would want to select a transistor that was capable of twice the necessary collector current.What is the ranges of transistor work ?
Rb = (voltage_of_signal_driving_the_base - 0.7v) / (Ic x 0.1). Not exact, but is close enough.How I calculate the resistor Rb that I need to switch SOL relay
The relay is dissipating 24mW? In that case, current is P/E = .024/12 = 2mA - doesn't sound quite right for a relay coil.I know that the nominal values are 12 Volt & 24 mWatt
If you mean the transistor's beta is 110 - you don't use the rated beta for transistor saturation. Use 1/10 collector current.Vcc=12 volt, Vcesat =0.2 Volt, Vin = 5 Volt, B = 110
If it's the transistor that's dissipating the 24mW, then Ic is roughly 110mA, and Ib is roughly 10mA. So, (5v-0.7v)/.010a = 430 Ohms.What it this circuit ?
Many will work. 2N2222 would be a likely choice.What is the ranges of transistor work ?
If the diode is not in the circuit, the relay coil will have a very high reverse voltage spike when the transistor turns off. This will likely destroy the transistor.What can happen if the diode cut oneself off ?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
