transistor
Discussion in 'General Electronics Chat' started by haditya, Mar 4, 2006.
  1. haditya
    Thread Starter Senior Member
    Jan 19, 2004
    220
    is there any standard method for identifying transistor leads for each of the packages
    is there any site that provides this with diagrams
  2. windoze killa
    Feb 23, 2006
    605
    24
    First answer is yes, there is a standard. Problem is that none of the manufacturers stick to it. For example a TO92 can have 3 or 4 different pin arrangements. Unfortunately this seems to be true for all case types.
    I can't remember the site address but it had pinouts for anything and everything. It was a Russian site and was excellent. I just can't seem to find it again after I had to reinstall afetr a big crash.
    Best way to determine a pin arrangement is to get the data sheet from the manufacturer.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings haditya,
    You may be able to find the pinouts for the transistor you are interested in at:
    www.datasheetarchive.com
    hgmjr
  4. wigginzhang
    Mar 15, 2006
    9
    Edited.
    No advertising of any kind is accepted.
