Go online, look up the xtr.Originally posted by isha@Nov 25 2005, 12:47 PM
when a transistor is in black box only three terminal are outside the box
and do not know that mid terminal is base
how can we label the three terminal with out measuring the voltge by multi meter across the terminal
[post=11936]Quoted post[/post]
Both Brandon and Moz are correct. If you are having trouble with both of those tests, you might consider that the device is a small signal mosfet or other device. On bipolar transistors the middle terminal is almost always the base. On small signal mosfets, however, the gate (similar to base) is usually one of the terminals that is not the center. Harbor Freight and Radio Shack both have inexpensive digital testers with plug in points for testing transistors, and that will tell all for bipolar transistors. Mosfets and J-fets will usually give a result similar to a bipolar transistor, unless you have recently touched the gate terminal with your finger, in which case they will show a low resistance between the other two leads.Originally posted by isha@Nov 25 2005, 12:47 PM
Oh yeah, when I said that the middle lead is almost always the base, I was referring to the small black transistors, TO-92 case. If the black box is around 5/8" inch square with a metal tab across the top, it's a TO-220 or possibly TO-246 or something like that, where the base is usually NOTthe center. If you can't read the lettering on the device as Brandon said, it gets tricky fast. A meter with a transistor checker might help.Originally posted by isha@Nov 25 2005, 12:47 PM
Off-topic.Originally posted by mozikluv@Nov 28 2005, 11:12 AM
hi,
i would like to add a little, for TO-220 casing the bjt Base is usually pin 1 assuming the transistor is facing you. but that is not the general rule of Base pin placement.
i would like to comment on the TO-92 silicon transistors. why can't the manufacturers agree on the specific placement of the pins. like having the base pin always at the center, the emitter at the left and the collector pin at the right. by my experience majority are placed like that, but there others who just loves to jumble those pin placement <_<
moz
[post=12015]Quoted post[/post]
thanks all of youcheck 1st to find out which legs are the E & C. if you get infinite resistance between them, even after reversing your probe, then that is your E & C. that leaves your B leg. this applies to both the NPN & PNP.
