transistor
Discussion in 'General Electronics Chat' started by saurabhkarnik, Oct 4, 2008.
  1. saurabhkarnik
    Jun 22, 2008
    22
    could u please suggest a transistor having Vbe on= 1.2v and IC >3amp
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That large a Vbe means it must be a Darlington. Just go to a manufacturer's site a do a parametric search. You will need to specify parameters like voltage and so on.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Look up the datasheet for a 2SC4242, NPN power transistor.
    Ic=4.0A when Vbe(sat)=1.2V, Ib=800mA.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    A TIP31 is a medium power transistor. Its base-emitter voltage is typically 1.2V when its collector current is 3A and its base current is 300mA.
