Transistor
Discussion in 'Homework Help' started by davidand, Jun 2, 2005.
  1. davidand
    Thread Starter Active Member
    Jun 2, 2005
    43
    Am I correct in stating that the input signal is applied to the base with reference to the emitter in a grounded emitter transistor?
    or is the input signal applied to the emitter with reference to the base?
    I'm confused with the text.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A grounded emitter transistor has the drive signal applied to the base, usually through a resistance to control base current. The output signal comes off the collector, and is phase shifted by 180 degrees. The collector is normally connected to a voltage source through another current limiting resistance. The ratio of abse to collector current gives the gain of the circuit.
