Transistor
Discussion in 'General Electronics Chat' started by imraneesa, Feb 19, 2015.
  1. imraneesa
    Dec 18, 2014
    189
    one of the circuit came with the amplifier giving the details of the transistor as 2SC1400 (E,U).
    what is (E,U) mean. when I see the board base emitter and collector are from right to left. but when I open the datasheet of 2sc1400 it is showing from left to right. is (E,U) has anything to do with it.
    is 2sc1400 (E,U) is not same as 2sc1400?
    Thanking in advance.
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Suffixes on Asian transistor numbers are usually gain bands - but E,U doesn't look like the usual format.
  3. Kermit2
    Feb 5, 2010
    3,845
    963
    from the data sheet...
    DC current gain (hFE)
    rank: F - 225-450
    rank: E - 350-700
    rank: U - 500-1000
    planeguy67 likes this.
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    Are you sure the orientation is the same for both view -- namely both looking down from the top or both looking up at the pins?
