Transistor without base pin.
Discussion in 'General Electronics Chat' started by cjdelphi, May 27, 2009.
  1. cjdelphi
    Mar 26, 2009
    272
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    In the case of an NPN transistor, the base needs to be about .7 volts more positive than the emitter.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Look at the datasheet of any silicon transistor. The absolute max allowed emitter-base voltage (reverse voltage) is only 5V to 7V. Because any higher and the junction conducts with "avalanche breakdown".
    This oscillator circuit has the emitter-base junction conducting with avalanche breakdown and it is in series with the forward-biased base-collector junction. That is why it uses a 12V supply.
  4. radiohead
    May 28, 2009
    474
    31
  5. mik3
    Feb 4, 2008
    4,846
    63
