transistor wired like this
Discussion in 'General Electronics Chat' started by spencer_manzon, Jan 7, 2011.
  1. spencer_manzon
    Dec 26, 2010
    8
    what would happen if I wire a transistor like this?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    BJT's are not suitable for parallel operation (particularly in linear mode) as you have shown without some form of current sharing control - such as a series resistor of appropriate value in each of the emitter terminals.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    The transistor with the lower Vbe at a given current will pass more than half the total emitter (collector) current. Since Vce's are equal, the one passing more current will heat up more than the other one, causing it to draw even more current. This is the beginning of thermal runaway. You can mitigate this by adding series emitter ballast resistors which drop around a few hundred millivolts at the anticipated current level.
  4. spencer_manzon
    Dec 26, 2010
    8
    @t_n_k : oh, i see. what values can you suggest? i'll be using a 2n3055 transistor.. what would be the power?
    @ron h: thank you :D
