could someone please explain why the LED glows in the following circuit without any base voltage when I touch the base lead. I observe that when I touch the base the Vbe voltage reads as 3.7V, when not touched it is fluctuating at 300mV. The transistor is MJE3055T.
I thought the transistor can conduct only when the base-emitter is forward biased but without any direct voltage just by touching the base the transistor seems to conduct??
Arvind
Arvind
