Transistor that has TWO emitters & Servo amp
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 1, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    What is this type of transistor called, and what kind of circuit's is it used in and for?
    The Transistors have a X crossing in the Servo amplifier, what does this X crossing do?
  2. DexterMccoy
    Feb 19, 2014
    429
    here are the schematics for them
  3. DexterMccoy
    Feb 19, 2014
    429
    This transistor has Two Emitters, look at the schematic
    What is it called and what kind of circuits is it used for and why does it have 2 emitters?
  4. DexterMccoy
    Feb 19, 2014
    429
    Servo Amp Q25 goes to Q29
    and Q26 goes to Q28
    What does this do? it's an X crossing pattern
  5. shteii01
    Feb 19, 2010
    3,505
    512
    That is not X crossing. There is no big black dot in the middle of the X.
    What you have is two wires that run from emitter of one transistor to the base of another transistor. The two wires are not connected to each other.
  6. DexterMccoy
    Feb 19, 2014
    429
    It seems they are used for RF modulation or modulation circuits for somereason but why 2 emitters?
  7. shteii01
    Feb 19, 2010
    3,505
    512
    One goes to transformer, another goes elsewhere.
  8. DexterMccoy
    Feb 19, 2014
    429
    But why use the 2 emitters to do this? for what reason?
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    They are the basis of TTL circuits and perform an AND function.
  10. DexterMccoy
    Feb 19, 2014
    429
    But why the 2 emitters? what does having 2 emitters do? why not 2 bases? or 2 collectors?
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Well an emitter will source current. So in a logic gate, if both emitters are high, there is no current flow from collector to either emitter and the transistor is off. This allows the collector to be pulled high.
    In logic terms "A high AND a high is a high"
    If either of the emitters is pulled low then the transistor is on and the collector is pulled low as well.
  12. DexterMccoy
    Feb 19, 2014
    429
    does a Base sink or source current?
    Does a collector sink or source current?
  13. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In an NPN the base and collector will both sink current and th emitter will source current. For PNP it is the reverse.
  14. DexterMccoy
    Feb 19, 2014
    429
    So why do they want to "choose" the pins that source current than to sink current?
    They aren't using the multiple emitter transistor as an ampilifer
    They are using the multiple emitter transistor as a Switch? so choosing sourcing current or sinking current shouldn't be a problem right? they could hook the signals to any pins of the transistor because it's used as a switch
  15. DexterMccoy
    Feb 19, 2014
    429
    SERVO AMP PICTURE:
    servo Amp Q25 goes to Q29
    and Q26 goes to Q28
  16. shteii01
    Feb 19, 2010
    3,505
    512
    The two wires don't actually connect in the middle, so the current from one wire DOES NOT enter the other wire.
  17. DexterMccoy
    Feb 19, 2014
    429
    Yes I know that, I'm not asking about that
    The X crossing pattern is a push pull arrangement?
    Because Q25 goes to Q29 WHY?
    Why does Q26 goes to Q28?
    Is this some type of push pull arrangement or what?
  18. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    The circuit is an H bridge motor driver. The two sides of the "H" must work in an opposite manner with respect to each other... hence the crossover connection.
  19. Billy Mayo
    Mar 24, 2013
    70
    Why do servo motors need an H bridge driver? What does the crossover connection do? If no crossover connection what will happen?
  20. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The purpose of an H bridge is to steer the current through the motor coil in both directions. In one of the directions the motor moves in the clockwise direction, and in the other direction it moves counter clockwise. A uni-directional servo motor is only useful for producing a controlled velocity. For position control it is like a WOM (Write Only Memory)
Thread Status:
