Transistor Switching, Minimum current for base?
Discussion in 'General Electronics Chat' started by Ishiyuu, May 25, 2016.
  1. Ishiyuu
    May 25, 2016
    Hello all,
    I have a very general question that seems to not yet have been answered. In a circuit I am designing, What I want is a 2n2222 transistor to only fire above a certain current. In a simulator, I am applying a 361.1uA current to the base, and am getting a 36.1 mA current. In reality, is it possible to completely limit the emitter current to 0 without the base being 0?
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    Welcome to AAC!
    How close to 0 do you require? Even with a large base resistor, there will be some leakage current.
    For anyone to be able to comment on the circuit you're simulating, you need to post a schematic.
  3. Ishiyuu
    May 25, 2016
    My apologies. My primary objective is to create a circuit whereby after 1 second of conducting, the circuit becomes "opened" for a period of time, where the base and collector connected cannot conduct current. I want to create this circuit in the most simple way as possible, without the use of gates or IC's.
  4. dl324
    Mar 30, 2015
    3,378
    651
    If you want the transistor to be saturated for a certain period after being triggered, you can make a discrete one shot to drive the switch. That will take 3 transistors, a capacitor, and some resistors.
    From wikipedia: https://en.wikipedia.org/wiki/Multivibrator
    You could try using an RC network on the base of a transistor, but you won't get a sharp on-off transition.
  5. crutschow
    Mar 14, 2008
    13,501
    3,375
    How long is this "period of time"?
  6. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    Yes. First, there is a minimum base-emitter voltage below which no base current flows. Once Vbe is large enough and base current does start to flow, there is a minimum current necessary to start collector-emitter conduction. These values are on the datasheet.
    ak
  7. wayneh
    Sep 9, 2010
    12,388
    3,244
    No. If there is any base current whatsoever, it appears at the emitter. It cannot accumulate in the transistor!
    Now, you could have a base-collector current if the collector voltage falls below the base voltage. But I don't think that's what you are asking.
  8. Ishiyuu
    May 25, 2016
    Thanks for the suggestions. I have found another solution however; I will use a relay instead
