transistor switching currents
Discussion in 'General Electronics Chat' started by puya, Oct 8, 2014.
  1. puya
    Oct 8, 2014
    I need to high speed transistor switching currents
    (load is Solenoid with 10 Amper)
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    How fast is fast?
    What will be the voltage of the powersupply?
    Bertus
  3. puya
    Oct 8, 2014
    Solenoid is 24v and Command 24v Coming from PLC
  4. puya
    Oct 8, 2014
    every 0.5 second
  5. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Is the 24V AC or DC?
    If 0.5 sec is the on and off total time, how long will the solenoid stay energised in each cycle?
    What are the solenoid inductance and coil resistance values?
    Have you considered how many on/off cycles the solenoid is rated for?
  6. crutschow
    Mar 14, 2008
    13,496
    3,373
    Any transistor will be much faster than the solenoid so transistor speed is likely not a consideration.
    What is the current and voltage signal output from the PLC?
  7. puya
    Oct 8, 2014
    Solenoid is 24v DC and coil resistance is 4 ohm and Command 24v DC Coming from PLC
    and Solenoid is on for 20 second
    I've used the transistor F9540N but operates with a lag
  8. Alec_t
    Sep 17, 2013
    5,972
    1,135
    I suspect the lag was due to the current build-up time in the inductance of the solenoid, or to mechanical inertia; not so much the transistor. Can you post a link to the circuit you used?
