transistor switch
Discussion in 'General Electronics Chat' started by hssucgang, Jul 19, 2007.
  1. hssucgang
    Jul 19, 2007
    is there any transistor switch or relay switch that works on 2 volts?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Two volts should work pretty much with all standard bipolar junction transistors (BJTs). This is not sufficient voltage to operate a field effect transistor. A darlington BJT transistor would probably not be a good choice.
    hgmjr
  3. GonzoEngineer
    Jul 8, 2007
    46
    Try an Optoisolator
  4. lightingman
    Apr 19, 2007
    374
    22
    If you are trying to switch 2 volts with a transistor, remember that the forward voltage drop accross the device is about 0.7 volts.....2 volts will switch a transistor on without a problem, through a resistor (about 2K2) into the base........ Daniel.
  5. ashok_ece2006-2010
    Jul 19, 2007
    plz provide the information about "B.L.THERAJA" ELECTRIC CIRCUITS 1 OF 3RD SEM
  6. nomurphy
    Aug 8, 2005
    567
    12
    Is 2V your source voltage (Vcc), or your drive voltage? In either case, the general answer is, yes.
    As noted above, a general bipolar transistor (2N3904 / 2N3906) only requires ~0.7V on the base-emitter. Some FET's can be used with a lower drive voltage, for example the NTD3055 FET requires a gate voltage of only 2V.
  7. nanovate
    Distinguished Member
    May 7, 2007
    665
    If you are going to drive a relay with a bjt you should not forget that you need to have enough current available to go into the base.
    Roughly I_C = I_B * beta
    I usually use beta = 50 for relay drive ckts (for margin) and look at the coil resistance and voltage of the relay to get my I_C. Then calculate the I_B. From this I can size the base resistor accordingly.
    R = (2V-0.7)/I_B
    Using R = 2K2 you can easily drive 30mA of coil current.
    John
