Hello all,
I'm hoping someone might be able to help me with this problem. I'll get down to the nitty-gritty but if more info is needed I'll explain further:
I have a connection in a circuit that requires either +6V to be applied, or 'nothing' to be applied... NOT grounded, but left floating.
All the transistor switch articles I've read require the load to be connected between the +6V and the collector of the transistor, but I don't have a negative 'return' from the circuit to connect to the collector.
I just need the transistor to act like a SPST toggle switch between the +6V power source and the circuit. Is this possible, and... how? I just can't work it out.
Perhaps it's confusing without knowing what it is. It's a 'clone' of an old analogue drum machine (sounds only). With the +6V applied the cymbal has a different attack than without. I want to control this using logic.
Hope I've given enough info, if not I'll give more.
Many thanks for any help you can give.
