Ron,
As previously stated in reply to Sgt Wookie's question......
"I see you're using a 12v supply. Is this thing going to be installed on a boat/car, or is this just an experiment with PSPICE?
My reply was.....
(working with the "12v Counter kit" I have)
"an "Equal out" pin (wire) that offers 5V @50ma when the count reaches a preset number (default=0000). One can preset any number into it, then begin the count, and upon reaching that preset number the pin/wire exhibits 5V @50ma, and that is the only way one can make the thing auto-stop counting, even on zero (actually, am going to use a couple more relays activated by the begin auto count buttons, (relay current values changed). See attached Pic
So, I had ordered some little 5V 20ma relays (just came in this afternoon)
and, yesterday decided to try and design a switching transistor to operate a relay I happened to have on hand (5V@89.3ma), and also decided to play around with the simulation program, thus winding up here on the forum, etc...."
See attached Pic--> K1 is this relay ! ! !
This Switching transistor/w/relay was/is a learning experience for me to know how to do it, etc....
Had I not recieved my 5v@20ma relays I would've used the design we just created.....
I used an 82 ohm resistor (1/4w) but it measured 80.5 ohms on my meter.
Yes, it got hot, figured it's pwr, supposed to be a little over .5W, will use a 1W if I ever build it for real, etc.....
Sarge,
Going lower in ohms (75 ohms) would probably work, but wouldn't I rather go higher to keep Ic lower=less pwr, and it would still work ?
Will copy all your info concerning the simulator, etc.
OK, got your attachment.....
My reply was.....
Sarge,
