Good. That's a 0.5% tolerance part rated for –40°C to 125°C.Wow, I lucked out - just checked and it looks like I purchased the TL431BQLPR
Per my suggestion back in post #24Good. That's a 0.5% tolerance part rated for –40°C to 125°C.
The new TL431 variant and LED should be fine.
Considering how critical the resistor values are to getting the correct trip points, and the tolerance of the TL431, you might find it worthwhile providing space on the PCBs to allow a trimmer resistor or two to be added at a later date if adjustment proves necessary.
Bear in mind that the LEDs and TL431 draw several mA continuously while the battery voltage is above ~6.3V. The green LED draws ~2mA more than the red LEDs in the circuit mod I posted.
Which circuit are you building? As per post #12, #16, #32 or #37?Mind just circling it on the diagram for me?
Awesome, finishing up the PCB design today then and i'll include those openings in case I decide that the 7.3v and 6.3v setpoints aren't really what I want.Yup, that's it for U3. A similar set-up for U4. Seems worthwhile if you're having PCBs designed and made.
BTW, where are you planning to use the circuit; Antarctica?
Different than what we're doing?When trimming a voltage divider like this, it is possible to get fine control by adding two five percent resistors in series, where one resistor is about 10% of the value of the other...
by Jake Hertz
by Duane Benson
by Jake Hertz
