Hmm...I'm not entirely sure how that affects the set points from looking at the different current draws throughout the temperature range. Is it drastic?The effect of temperature on both switching points. Green is -40C, 100C is dark Blue. Steps are 20C each.
I think it might be fine....not sure about internal resistors on them, but I looked up at the RED led has a Vf of 2.0 V (2.5 max?) and the GREEN has a Vf of 2.2 V (2.6 max?). Will these still work?As long as the ones you are using do not have an internal resistor, like most panel mount LEDs have. To work as simulated, the Vf for the Red and Green LED should be between 1.8V and 2.2V.
