Hi, I'm looking for transistor suggestions to use in a differential amplifier. I need a pair of N-channel MOSFET's or JFET's to use and could use some suggestions on which ones to use. The supply voltage will be 0 to 5 volts and the input signal will be around 100 to 300 mV not including any offset.
Thanks a lot,
Mike
Thanks a lot,
Mike
