Transistor ST83003 negative voltage issue
Discussion in 'General Electronics Chat' started by makrotek, May 24, 2016.
  1. makrotek
    May 24, 2016
    I charge 250VDC ( 80khz, square wave ) to a transistor ST83003, I got -12V between two
    wave. I am looking for a solution for the -12V issue. Anyone have the solution
    please advise. Thanks.
  2. #12
    Nov 30, 2010
    16,704
    7,354
    Post your circuit drawing.
  3. makrotek
    May 24, 2016
    Circuit drawing attached. Please advise. Thanks.
  4. makrotek
    May 24, 2016
    Circuit attached. Thanks.
  5. #12
    Nov 30, 2010
    16,704
    7,354
    The only place I can see where you have a negative voltage is R80. Why is it connected to -16 volts?
  6. makrotek
    May 24, 2016
    The -16 is for adjusting zero voltage for other control.
    We measure from the output the negative voltage as described in the attached document.
    Just like jumping on a bouncing bed. The higher the positive charge, the higher the negative charge generated.
    I have used this circuit for year. Now I want to solve this issue. It seems that after charging the transistor, the transistor will generate negative
    Charge. Please help.
  7. crutschow
    Mar 14, 2008
    13,508
    3,385
    I see no ST83003 transistor in your schematic. :confused:
    Which one did you change?
