transistor source
Discussion in 'The Projects Forum' started by sasek, Apr 12, 2010.
  1. sasek
    Jan 3, 2010
    64
    hai alll
    Here I want asking few question, could phototransistor work with AC source at collector and emitter terminal??? If possible what max voltage I could put over there, because i tried to find max voltage that phototransistor could support from a datasheet but not included.
    Thanks........:D
  2. retched
    Dec 5, 2009
    5,201
    313
    As long as the gate was supplied with a constant DC, It may work..
    sasek likes this.
  3. sasek
    Jan 3, 2010
    64
    is it collector have voltage limit???
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ahh, wait a minute....
    Are you trying to say you want to use a phototransistor with mains AC power?
    What exactly are you trying to do?
  5. retched
    Dec 5, 2009
    5,201
    313
    Ive got to start thinking early in the morning before I start responding..
    I was thinking in terms of low voltage a.c. I couldnt imagine them wanting to put 120vAC or 240vAC through a phototransistor. But I should have asked first.
    Are you wanting to try to use a phototransistor as a photo driven relay?
  6. sasek
    Jan 3, 2010
    64
    yup. i want use as driven relay with nice response
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, you can't use a phototransistor with mains power.
    You need to use low voltage DC with a phototransistor.
  8. sasek
    Jan 3, 2010
    64
    hummm...
    thanks info me.......
    do you know the suitable distance to separate LDR and LED to make them have good or maybe very good response....
    thanks reading :)
  9. retched
    Dec 5, 2009
    5,201
    313
    I think you may be trying to recreate the workings of a Solid-state relay. Have a look at SSR.
  10. sasek
    Jan 3, 2010
    64
    hummm actualy not.....
    im trying to control thyristor gate using digital method....... so i need analog optocoupler to control the firing angle. actually, thyristor gate depend on what???? current or voltage?????
