transistor selection help
Discussion in 'General Electronics Chat' started by whale, Dec 17, 2009.
  1. whale
    Thread Starter Active Member
    Dec 21, 2008
    111
    CAN I USE BFQ136 TRANSISTOR AS AN AMPLIFIER FOR THE FREEQUENCY RANGE ABOUT 13 MHZ?
    I HAVE ITS DATA SHEET . THE TERMS IN ITS DATA SHEET ARE AS FOLLOWS,
    transition frequency(fT) = 4.0 - GHz
    CONDITIONS : IC = 500 mA; VCE = 15 V; f = 500 MHz; Tj = 25 °C;
    please explain me about the term transition frequency.
    is the transistor is suitable for 13 mhz operation?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That transistor is not at all suitable.
    Take a look at the site - http://www.kenselectronics.com/lists/orig.htm - and find any transistor rated for the RF output of a CB radio. If it will work at 27 MHz, it will work at 13 MHz.
  3. whale
    Dec 21, 2008
    111
    thanks beenthere ,
    can you tell me whats the term transition frequency mean?
  4. whale
    Dec 21, 2008
    111
    tell me how to choose a transistor based on the frequency of the circuit.
    i mean, what factor in the data sheet is responsible for the frequency of operation?
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  6. Ron H
    Apr 14, 2005
    7,050
    657
    In a transistor, transition frequency is the frequency where the AC current gain (beta, hfe) equals one.
  7. Ron H
    Apr 14, 2005
    7,050
    657
    Whale, as beenthere said, a transistor with fT=4GHz will be unsuitable. It would be difficult to keep it from oscillating unless you really know what you are doing.
