Transistor saturation
Discussion in 'General Electronics Chat' started by greenberet, Nov 16, 2006.
  1. greenberet
    Nov 13, 2006
    9
    what is all this about transistor haveing a saturation delay hen switching between cutoff and saturaton.
    I dont see why such a things should happen. Can someone explain it based on the water analogy of the transistor.
  2. n9352527
    Oct 14, 2005
    1,198
    Every transistor, I assume we are talking about BJT here, has base capacitances. When the transistor in cut-off mode, the base is at the same potential as the emitter. The base-emitter capacitance is therefore is empty of charge, while the base-collector capacitance is fully charged.
    When base current is applied, the current has to charge the base-emitter capacitance and discharge the base-collector capacitance. With finite value of maximum base current, the time taken to charge/discharge these capacitances are also finite. It is this charging/discharging time that causes the turn-on delay from cut-off to saturation.
    The same mechanism exists when the transistor is moving from saturation to cut-off, except the charging/discharging are now reversed. However, the amount of charges might be a little bit more in this case, causing a longer turn-off delay compared to turn-on delay.
    Water analogy? Hmm... let's just say it takes time to turn the faucet on and off :d
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    And the faucet has resevoirs that must be filled and emptied before the flow or lack therof is evident.
