Transistor replacement …..
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 3, 2008.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    :confused:.......... When a faulty transistor is replaced with a similar type one, ( when it’s not possible to find an exact one) what are the important factors to be considered?
  2. Externet
    Nov 29, 2005
    775
    57
    Polarity, voltage, current, gain, frequency of operation, size. :)
  3. Ron H
    Apr 14, 2005
    7,050
    657
    It depends on the application. Can you post a schematic and/or or describe the application?
  4. kubeek
    Sep 20, 2005
    4,686
    805
    Voltage, current, package, gain (or gate capacity for mosfets). And maybe lots more depending on the circuit design&demands.
  5. Bailey45
    Member
    Oct 27, 2008
    18
    If the transistor is used in audio equipment it may be one half of a "matched pair". In this case you must replace both transistors with a suitable " matched pair.
