Transistor replacement/substitution
Discussion in 'The Projects Forum' started by Pencil, Jun 10, 2011.
  1. Pencil
    Thread Starter Active Member
    Dec 8, 2009
    271
    38
    I am looking for a replacement for a transistor
    taken from a Pioneer receiver, 15W output, ≈30 yrs old.
    The transistor is marked: B507P EOL
    Seems to be paired with a D313P (marked: D313P EOK)
    Package type: TO-220
    I have attached a possible datasheet, although I am not
    sure if it is the same brand as I cannot find any identifiable
    brand marking. I do not have a schematic at this time.
    I assume I will need to replace both transistors of the pair.
    Maybe even replace both pairs.
    Prefer DIGIKEY, but any major distributor (<$51 minimum order) O.K.
    (I only mention this to avoid asking over and over. I appreciate any
    suggestions.)
    I could probably work with different pinout configuration as long as
    it is same package type.
    EDIT: #$&*$@&!, I meant to post in the GENERAL FORUM.
  2. #12
    Nov 30, 2010
    16,665
    7,310
    nte153 = 2sb507p
    nte512 - 2sd313
    mcm, parts express, and Mouser also come up on the search page as NTE suppliers.
    Oops, I made a typo.
    nte152 is correct.
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
  4. Pencil
    Dec 8, 2009
    271
    38
    Thanks guys.
    Comparing datasheets now.
    Just an FYI for anyone who stumbles
    across this thread searching for the same
    thing, the one I removed was shorted collector
    to emitter. Cause unknown at this time.
    Thanks again.
