Transistor Recommendation
Discussion in 'General Electronics Chat' started by jsthomps, Oct 7, 2012.
  1. jsthomps
    Mar 30, 2010
    15
    I'm building a pinball project that requires a microprocessor to control up to 100 Incandescent 6.3V 250ma miniature bulbs. Assuming a 10 x 10 matrix, each row and column transistor would have to hand 2.5amps at 6.3volts if all lights were turned on. Can anyone provide me with with a transistor recommendation for this project?
    Thanks,
    Scott
  2. Pencil
    Dec 8, 2009
    271
    38
    You should probably looking for an N-channel MOSFET.
    What is the output voltage of your microprocessor?
    Through hole or surface mount component?
    Single or array (multiple per package)?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Why are you using stone-age incandescent bulbs that waste most of their input power making heat instead of light?
    Why not use solid state modern LEDs instead?
  4. jsthomps
    Mar 30, 2010
    15
    I want to recreate the ambiance of a 1940 pinball machine. I acquired a game that was in beautiful condition but some knuckle head ripped out all of the electrical components save light and switches.
  5. jsthomps
    Mar 30, 2010
    15
    I'm using an Arduino which I believe provides 5V outputs. Through hole for sure ... I'm years away from surface mount
  6. tracecom
    Apr 16, 2010
    3,879
    1,396
    IRLZ44N is more than capable and works with a logic level input.
  7. dataman19
    Member
    Dec 26, 2009
    136
    29
    Post the pinball machine.
    We may be able to find a wiring manual. Then you "may" actually be able to restore it (can be worth some bucks restored and working).
  8. jsthomps
    Mar 30, 2010
    15
    Unfortunately all the steppers and relays were removed. If they were intact that would have been my plan A. Thanks for offer to help.
    Regards,
    Scott
