Transistor Question
TomWhitfield
Joined Apr 5, 2013
5
Hi all,
I've registered to this forum simply to ask a question regarding my transistor :)
I have a circuit which is powered by 12v, my transistor is getting really hot (cannot touch it for long before it burns my fingers!). My circuit works fine for a short amount of time, then it just stops functioning. if I turn off the power for a few hours and come back, it's working again.
Does this sound like a heat problem? Would the heat prevent the transistor from functioning? I am new to electronics but the project I'm doing is almost done, it's just annoying that it only works for 5-10 minutes before deciding to give up.
All details are below for the type of transistor I'm using...
TRANSISTOR, NPN, TO-92
Transistor Polarity:NPN
Collector Emitter Voltage V(br)ceo:40V
Power Dissipation Pd:625mW
DC Collector Current:600mA
DC Current Gain hFE:300
Transistor Case Style:TO-92
No. of Pins:3
Collector Emitter Voltage Vces:200mV
Continuous Collector Current Ic Max:600mA
Current Ic Fall Time Measurement:10mA
Device Marking:2N2222
Fall Time @ Ic:250ns
Full Power Rating Temperature:25°C
Gain Bandwidth ft Min:300MHz
Gain Bandwidth ft Typ:300MHz
Hfe Min:75
No. of Transistors:1
Package / Case:TO-92
Termination Type:Through Hole
Thanks in advance people! :)
bertus
Joined Apr 5, 2008
22,278
What are the ratings of the motor?
What is the value of the resistor in the base of the transistor?
Bertus
TomWhitfield
Joined Apr 5, 2013
5
Resistor Info
470 Ohm 0.25W Resistors
CR25 high stability carbon film Resistors
Operating Temperature: -55 to +125 C
Wattage: 0.25W
Max. working voltage: 300V
Max. overload voltage: 600v
Body dims. (L x dia): 6.5 x 2.5mm
Leads dims. (L x dia): 28 x 0.6mm
I'm not 100% sure on the motor I'm afraid, all I know is that it is a 12v motor, 300RPM & uses around 5W @12v DC.
Hope this helps?
WBahn
Joined Mar 31, 2012
30,087
If the motor is using 5W at 12V, then that says that the motor current can be on the order of 500mA. That's pushing the max ratings of that poor 2N2222 pretty hard.
You are giving out tons of detailed spec information but not very much of the basic information that is really needed. For instance, what is the voltage that is being put on the "GPIO Pin 18" when you are turning the motor on?
Let's say that it is 5V. That means that you have about 4.3V across the 470Ω base resistor. Let's call it 4.7V so that we are getting about 10mA of current into it. I don't know how far into saturation you are going to get with that base current. Can you measure the voltage across the collector and emitter pins while the motor is running?
TomWhitfield
Joined Apr 5, 2013
5
Hi WBahn, thanks for the response.
I do not own a voltmeter unfortunately. I was following a build log and I noticed the guy was using 6v for power and not 12v, I just chose the transistors he recommended. As I said, it works perfectly but decides to stop randomly (I just presumed it was due to the heat).
Could you possibly provide me with a model of transistor that should be able to cope a lot better than the current one? Ideally using the below site so I could pick some up from the store tomorrow :)
http://www.maplin.co.uk/productsearch?criteria=transistor
Thanks! :)
WBahn
Joined Mar 31, 2012
30,087
The site just wanted to keep loading cookies on my machine. My tolerance for that is very low.
I did see that they had mutlimeters for as low as 8 (pounds?). Get one.
You can probably get by with most any general purpose transistor that is in a TO-220 or similar case. I saw they had TIP3055s. That's probably overkill, but would work (provided you can get enough base current into it).
We still need to know what you are using for your input. How many volts and what kind of current is it capable of?
timescope
Joined Dec 14, 2011
298
What of a logic level mosfet ?
Bipolar transistors need huge base currents to get them to saturate properly at high current levels.
The 2N2222 datasheet specifies Vce sat = 1.0 v @ Ic = 500mA, Ib = 50mA.
Timescope
