Transistor question
Discussion in 'Homework Help' started by chaosdestro0, May 1, 2011.
  1. chaosdestro0
    Apr 30, 2011
    10
    I am having difficulty understanding how you would find the voltage across R2.
    Let's say I had this circuit, with Vout as 4.4v and a voltage drop across the diode at 2v. From the mark scheme, it says do 9-2-4.4. I am not sure why this does this, can anyone explain?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Do you know II Kirchhoff's law (KVL)??
    For your circuit KVL must hold
    Vcc = Vout + VR + Vd = 9V
    VR = Vcc - Vd - Vout
      File size:
      7.4 KB
      43
    chaosdestro0 likes this.
  3. chaosdestro0
    Apr 30, 2011
    10
    Wait, so why does the voltage from the v out of the transistor not add to the 9v?
    I have done work on it but without additional sources.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Well, I don't understand you question.
    Can you specify your question.
    Your circuit has "external 9V additional sources".
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Because they are of opposite polarity. Look at the arrows drawn for you.
    If you put two 1.5 volt batteries in series, same polarity, they add, you see 3V across both.
    If you put two 1.5 volt batteries in series, but opposite polarity, they subtract, and you see about 0V across both.
  6. jegues
    Sep 13, 2010
    735
    43
    If you are confused about the arrows, it basically indicates how one would attach a voltmeter to the circuit.
    See the figure attached.
      File size:
      41.6 KB
      16
  7. chaosdestro0
    Apr 30, 2011
    10
    Now I see it, Cheers :).
