Transistor question
Discussion in 'Homework Help' started by terrytapp, Dec 1, 2006.
  1. terrytapp
    Mar 30, 2006
    15
    A transistor with outputs from the emiiter and the collector
    a) will not work
    b) will have equal amplitudes and polarities at each point
    c) will have opposite polarities at each output
    d) will output positive portions on the collector and negative portions on the emitter
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Which answer do you think it is? And why?
    hgmjr
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I think there is not enough information to answer the question. It would help to see a schematic.
  4. terrytapp
    Mar 30, 2006
    15
    I am thinking C
    Because the output of the emitter is 180 degrees from the input and the collector output is in phase with the input, so the two outputs are 180 degrees out of phase from each other.
  5. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Depends how it has been wired.....
    As a general case however, eliminate what is obviously wrong and what is left must be the required answer. You seem to be on the right track, explain why you think the answer is C...
    BTW, do you think that any of those answers would apply if wired in Common emitter mode....especially with a grounded or bypasssed emitter..... ?? What is the purpose of AC bypassing on the Emitter..?
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Out of all the answers available, I too would choose C. I would do so for the reasons you have stated.
    hgmjr
  7. JoeJester
    Apr 26, 2005
    3,402
    1,223
    I would have chosen C ... the circuit typically is a phase splitter.
    As I recall, the emitter output was in phase and the collector output was 180 out from the input signal.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    I'm red-faced. Joe is absolutely correct.
    That is what I get for speed reading the reason that terrytapp stated.
    Thanks for catching that hiccup on my part.
    hgmjr
