I have worked with transistors in the past, but only with one circuit. I am looking to set up this schematic but with different voltages:
I have unsuccessfully played around with setting it up in a new configuration. The power source is 18 VDC and the voltage to the base is 5VD. How do I calculate the values for the different voltages, for now and in the future? I am using a 2N3904 transistor, do I have to worry about the 18VDC with that transistor? Thanks in advance for any help!
-Eschatt
-Eschatt
