Transistor Problem
Discussion in 'General Electronics Chat' started by ahmedzica, Jan 10, 2012.
  1. ahmedzica
    Jan 9, 2012
    20
    I've a circuit like that
    I'm trying to determine R1,R2,Re and Rc
    When Ic= 10mA and, Vce=8v and Bdc=75
    I've done my best and I got 3 equations
    Here is them
    14= 10Rc+10Re
    22-Vb= 10 Rc + 7.3
    Vb= 10 Re + 0.7
    and i cannot go on :(
    Can anybody help,please?
  2. colinb
    Jun 15, 2011
    351
    35
    Don't forget your units in the equations. Otherwise you'll get wrong answers. If you just insert a lone “10”, it is not the same as “10 mA”.
  3. ahmedzica
    Jan 9, 2012
    20
    I see but I'm just wrinting my equations . I've 3 equations with 4 unknws so I'm tring to get the fourth one
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    What about Vcc ??
  5. Jony130
    Feb 17, 2009
    3,990
    1,115
    Try this this is the rule of thumb.
    R1 = (Vcc - Vb) / (11 * Ib)
    R2 = Vb / (10 * Ib)
    For good thermal stability we choose Ve to be grater then Vbe.
    So for good thermal stability we usually choose Re=(0.1 ... 0.4)*Vcc/Ic or Ve large then 1V (Ve>>Vbe)
    Rc = (Vcc - Vce - Ve)/Ic
  6. ahmedzica
    Jan 9, 2012
    20
    Vcc = 22v volt
  7. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    One equation ( at least ) should include some parameter of the transistor. Think about it.
  8. ahmedzica
    Jan 9, 2012
    20
    I already did :(
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    So for Vcc = 22V and beta = 72 ; Ic= 10mA; Vce=8V
    Rc + Re = ( 22V - 8V) / 10mA = 1.4KΩ
    I choose Rc = 1.2 KΩ and Re = 200Ω
    Ve = Re * Ie = 200Ω * 10.138mA ≈ 200Ω * 10mA = 2V
    Vb = Ve + Vbe = 2.65V
    Ib = Ic/beta = 10mA/72 ≈ 139μA
    R1 = (22V - 2.65V) / (11 * 139μA) ≈ 13KΩ
    R2 = 2.65V / ( 10 * 139
    μA) = 2K
  10. ahmedzica
    Jan 9, 2012
    20
    How come Rc=1.2 KΩ and Re= 200 KΩ!! isn't anyway but this i.e away from guessing ?
  11. ahmedzica
    Jan 9, 2012
    20
    200Ω*** Sorry
  12. Jony130
    Feb 17, 2009
    3,990
    1,115
    From this
    Vcc = Ic * Rc + Vce + Ie*Re
    And if we assume Ic = Ie
    Rc+Re = ( Vcc - Vce)/ Ic
    = ( 22V - 8V)/10mA = 1.4KΩ
    So I choose Rc = 1.2K and Re = 1.4K - 1.2K = 200Ω
  13. ahmedzica
    Jan 9, 2012
    20
    I know I'm asking about the latest stop why choosing Rc=1.2 based on what! and should RE=>10R2 in order for this Voltage divider to be stiff
  14. Jony130
    Feb 17, 2009
    3,990
    1,115
    Usually we choose Rc > Re for for several reasons.
    The first one and perhaps most important reason is that Re reduces the amplifier output voltage swing. And the voltage gain is equal to Rc/Re.
    I use some other condition to achieve the desired voltage divider stiffness.
    I choose voltage divider current much larger than the base current (10 * Ib typical). This is almost the same condition as yours.
  15. ahmedzica
    Jan 9, 2012
    20
    oh ok thanks :)
