transistor measure ok but not working
Discussion in 'General Electronics Chat' started by TAKYMOUNIR, Sep 16, 2011.
  1. TAKYMOUNIR
    Thread Starter Active Member
    Jun 23, 2008
    351
    i have circuit it has transistor is bad but this transistor measure ok when i check it by meter, but when i change the transistor the circuit work ok and i compare the reading of the 2 transistors is the same so my question is why the transistor measure ok but not working is this could be the gain is different or what?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Supply your schematic.
    hgmjr
  3. Veracohr
    Jan 3, 2011
    559
    77
    How are you 'measuring' the transistor? What kind of meter, what kind of measurement?
  4. TAKYMOUNIR
    Jun 23, 2008
    351
    i use fluke meter and i measure the diode junction(vd)
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Did you measure:
    1) Base to emitter, both forwards and backwards, reading ~0.7 one way and open the other?
    2) Base to collector, both forwards and backwards, reading ~0.7 one way and open the other?
    3) Emitter to collector and collector to emitter, both indicating open?
    TAKYMOUNIR likes this.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    /The "two diode test" of a transistor isn't much of a test. You need to essentially check every pin to every other pin to make sure there isn't leakage or shorts, as well as looking for open pins. Checking a transistor by treating it like 2 diode tests pretty much gives you an idea of the pinout and type (PNP or NPN)
    Some multimeters (for some reason, the cheap ones) will have a gain measurement circuit for transistors, so if it passes that, it is more than likely fine.
    There are a lot of simple build yourself Transistor testing circuits, I've built a simpler version of this one, I didn't use thee 4066 switch, just 3 momentary switches instead, and bi-color LEDs instead of 2 for each leg:
    http://www.redcircuits.com/Page83.htm Has the info and description, I'll try hotlinking the schematic:
  7. TAKYMOUNIR
    Jun 23, 2008
    351
    it measure .7v in forward only and open in backward
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Did you check both the base-collector and base-emitter junctions, as well as measuring the emitter-collector forwards and backwards?
  9. Adjuster
    Dec 26, 2010
    2,147
    300
    Apparently correct forward and backward results for the collector-base and base-emitter junctions tested as diodes does not prove that a transistor is good.
    There could be excessive collector-emitter leakage, or even a dead short between them. The current gain could be very low (or excessively high - but that's less likely to be a problem).
    Measuring the two junctions separately does not even prove that you have a transistor at all - two separate diodes in the same encapsulation would "pass" this test, but could not provide any amplification.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I can't seem to get an answer from our OP if they tested all possible combinations. :confused:
