Transistor latching circuit problem
Discussion in 'General Electronics Chat' started by TheNight Silence, Apr 3, 2016.
  1. TheNight Silence
    Feb 4, 2016
    13
    Hi all
    I've made a latching switch using a transistors but it's not working as it supposed, and i don't know why
    When pressing the push button the led is lit but it's not latched since it turns off when depressing the switch
    pls help why it's not latching the output voltage?
  2. #12
    Nov 30, 2010
    16,665
    7,310
    Add a diode from the top of R2 to the left of R4.
    When the push button applies Vcc to R2, Q2 has no voltage across it and thus doesn't get involved in the current flow.
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    To avoid any possibility ambiguity, the diode #12 suggested you use should be in series with the wire going from output to input and the diode anode should be towards R2.
    #12 likes this.
  4. #12
    Nov 30, 2010
    16,665
    7,310
    You know how it is. I assume a person that can make this circuit would know a diode in parallel with a wire won't change anything.
    But, there I go assuming again.:oops:
  5. cmartinez
    Jan 17, 2007
    3,698
    2,757
    Couldn't make it latch either :oops:
    Maybe I did something wrong with the sim. V2 delivers a short pulse through D3, thus simulating a switch, IMHO. But current flows through the LED at all times, 5.774mA when V2=0 and 5.775mA when V2=5
    However, if I simply cut out D3, and leave V2's positive side floating, the circuit does latch... what's going on????
    What am I doing wrong?
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    It's look like some kind of "simulation artefacts". To fix this try in "Edit Simulation Command" window just turn on the option "Start external DC supply voltages at 0V".
    cmartinez likes this.
  7. crutschow
    Mar 14, 2008
    13,475
    3,362
    You are doing nothing wrong. It's just that, for whatever reason, the circuit goes into the latch mode when LTspice is doing its initial DC bias calculation before doing the transient analysis
    If you start the supply voltage at 0V, it works.
    Edit: Jony beat me to it.
  8. TheNight Silence
    Feb 4, 2016
    13
    Thanks for you my friends ,
    i will try your suggestions and i will come back with the results
    B.R
  9. TheNight Silence
    Feb 4, 2016
    13
    Hi friends
    I've put a diode as your suggestion,but sorry it doesn't work,even the led didn't lit when i press the switch
    when releasing the button
    The voltage across the diode= -5V,Vc(Vout Q2)=-.094 V(with respect to ground),Vbe(Q1)=4.98V
    when pressing the switch
    The voltage across the diode= -4..65V ,Vc(Vout Q2)=-0.91 V(with respect to ground),Vbe(Q1)=4.98V
  10. TheNight Silence
    Feb 4, 2016
    13
    the diode is reverse biased in the two state
  11. cmartinez
    Jan 17, 2007
    3,698
    2,757
    How about changing R1 to 1.2k?
  12. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    I also use a voltage source and a series diode to simulate a switched input, mainly because I've never figured out the LTS switch component. But I make the voltage source a pulse with a visible delay and relatively slow rise and fall times so I can see how the transition affects each circuit element. For this circuit, a 1 second delay and 1 second rise time makes the circuit latch every time, with or without D2.
    ak
  13. cmartinez
    Jan 17, 2007
    3,698
    2,757
    Wouldn't that be the equivalent of adding a capacitor in series with a resistor?
  14. crutschow
    Mar 14, 2008
    13,475
    3,362
    Vbe(Q1) cannot be 4.98V if it's properly connected. It should be no more that 0.8V.
    Below is the simulation with the LTspice switch model. I added a resistor between the base and emitter of Q1 to take care of any leakage currents and help insure that it powers up in the OFF state.
  15. AnalogKid
    Aug 1, 2013
    4,685
    1,297
    Maybe, but I'm not suggesting it as a circuit mod. It is a way of seeing what the simulator thinks the circuit is doing.
    ak
  16. GopherT
    Nov 23, 2012
    6,303
    4,019
    This seems easier unless the OP needs a ground connected LED.
    catfibres and cmartinez like this.
  17. cmartinez
    Jan 17, 2007
    3,698
    2,757
    It does indeed... I bet (not my life though ;)) that there's an equivalent circuit for a grounded LED
  18. GopherT
    Nov 23, 2012
    6,303
    4,019
    Probably, I just didn't bother designing one. The one in above post was my best memory of an SCR from discrete transsotres. PNPN.
    In simulation, swapping the current limiting resistor and LED cause the circuit not to latch. In both cases below. They work fine as shown.
  19. TheNight Silence
    Feb 4, 2016
    13
    really i need the circuit to be controlled by single pulse from my PC serial port which is generated by a peace of software,
    so i need the circuit work from single push button, since i will remove it and apply the control signal in stead;
    i hope you could help
  20. AnalogKid
    Aug 1, 2013
    4,685
    1,297
    If the PC output pin is making a positive pulse, you will need to connect it to the left side of R4 through a diode (1N914, etc.) to prevent a transient conflict between the PC output and Q2 collector.
    ak
