Transistor in Common Emitter Circuit
Discussion in 'Homework Help' started by David Waddell, Dec 8, 2014.
  1. David Waddell
    Dec 3, 2014
    24
    Explain the operation of the transistor in this Commom Emitter circuit with reference to base,collector and emitter currents.
    • Collector Current ic = 800mAdc
    • Gain HFE = 100
    • Collector Base Voltage – 75Vdc
    • Total Power Dispersion – 500mW
    Thanks for any help
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    So, if you have simulated it, you should be able to see how it works...
    If you want to use a text-book model and use calculations, then show us what you have already tried...
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    So what have you done so far in determining those currents?
    Do you know how a transistor works?
  4. Anthony Volkman
    Feb 13, 2015
    rutschow, post: 791473, member: 19451"]So what have you done so far in determining those currents?
    Do you know how a transistor works?[/QUOTE]
    A transistor is an electronic switch that opporates like a valve, there a three pins, the most simple one is an npn transistor ( the order on most is basec collector, and emitter). The base, is where a small signal such as an audio signal from your headphone Jack from your cellphone or other audio source. This controls the voltage between the collector and emitter. Next, the collector, the collector is where the positive rail from your power supply goes in, then your negative goes into the collector. The collector gets your load,( led, speaker, motor, even a relay). Now a small signal transistor uses a very small signal( including, a headphone Jack signal, possibly a microphone, a piezoelectric transducer, even if you just touch the base and emitter pins with your finger).
  5. WBahn
    Mar 31, 2012
    18,089
    4,917
    This is a rather poor and misleading description of how a transistor works. For instance, the claim that the voltage at the base controls the voltage between the collector and emitter. Whether this even appears to be the case is dependent on the circuitry that the transistor interacts with and not the transistor itself.
    The statement, "the collector is where the positive rail from your power supply goes in, then your negative goes into the collector," is nonsensical.
    A small-signal transistor does not necessarily use a small signal. In fact, the input signal may be as large or even larger than the output signal.
  6. #12
    Nov 30, 2010
    16,705
    7,355
    Your data in the first post is mostly wrong. It is your job to start figuring out the currents and voltages.
    Start with R1 and R3.
  7. Dodgydave
    Jun 22, 2012
    5,159
    772
    At a guess i would say approx 2.5mA Ic, Vce 4V.
  8. crutschow
    Mar 14, 2008
    13,509
    3,385
    How about letting the op do something. :rolleyes:
  9. WBahn
    Mar 31, 2012
    18,089
    4,917
    I second the motion.
  10. #12
    Nov 30, 2010
    16,705
    7,355
    First rule in Homework: Don't just hand them the answer. Help them understand it.
  11. WBahn
    Mar 31, 2012
    18,089
    4,917
    What data is wrong. These seem to be straight out of the data sheet, though of course the hfe is given as a specific value instead of a min or a range.
  12. #12
    Nov 30, 2010
    16,705
    7,355
    Oops. I thought the data was the specs for this circuit. :oops:
  13. WBahn
    Mar 31, 2012
    18,089
    4,917
    I was wondering that at first, too. It took a bit of head scratching to conclude that it was meant to be datasheet info. The 75V spec was the one that steered be in that direction pretty quickly.
