Transistor identification
Discussion in 'General Electronics Chat' started by Rotex, Jul 18, 2009.
  1. Rotex
    Jun 25, 2009
    5
    Can someone pls tell me how to know if a transistor is npn or pnp by mere reading the part number.
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. millwood
    Guest
    the generic answer is "no". you typically will have to look at a datasheet to see that for sure.
    however, some countries use certain naming convention on some of their transistors (2sa/2sb/2sc/2sd and 2sj/2sk for the japanese for example). but that's not done consistently across time or across manufacturers.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    As far as I know, there is no transistor part numbering convention that can be relied on across manufacturers.
    hgmjr
